Tally is not only an application, but also a complete development environment which enables the programmers to build extensions, customizations and integrations using Tally Definition Language (TDL). TDL allows programmers to build a faster application without compromising on Speed, Reliability or data Integrity, which is core to Tally.
Extensions do not impact any of the core features of Tally that you love. You continue to enjoy the speed, simplicity and flexibility of your Tally
Extend, Customize or Integrate your Tally fast
Add or remove any extension at any given point of time without compromising data integrity and reliability
Extensions are new functionality built over default Tally features. You can extend TallyPrime with more than 800+ ready-to-plug-in extensions. You can enhance your business by adding a feature, functionality, office productivity tools, and so on by adding the extensions available in ‘Tally Shop’
Choose from an entire range of add-ons across 17 categories such as Invoicing, Workflow Management, Business Verticals, Alerts & Controls, and many more. All it takes is ONE CLICK and the Add-on is streamed into your PC, installed, licensed and immediately available for use! Buy, Install, Use…in seconds!
Starting from Rs.283, you can now easily locate, evaluate and buy these extensions from Tally Shop.
Looking for feature or functionality to meet your unique business requirement? Build it for your business in a way you want. Tally Definition Language (TDL) provides complete flexibility and power to customise the solutions for complex business requirements with ‘Power of simplicity’.
Tally Partners are Trained and Certified to build new capabilities and functionalities to meet your business requirements. Talk to one today.
TallyPrime has been designed to provide extensive integration capabilities that enable businesses to build cross-platform solutions without compromising data integrity and reliability. Thus, empowering business to seamlessly interact with multiple applications or software systems..
Integration capabilities in Tally allow two-way data transfer, which means pulling data out from Tally database or pushing data to Tally is as easy as it could ever get. Tally allows integration between applications/databases in two modes
Over the period, our certified partners have built several integrations ranging from Device integration, Dealer Management systems, Data migration tools for various software systems and so on. Looking for it? Talk to our partner.
